Copy and paste autocad dwg into SW sketch - Degree symbol problem
I copy and pasted an Autocad dwg into a SW sketch. Conversion worked pretty good except for degree symbols, they are showing %%D in the SW sketch(see attached).
Typically not a problem, but I have a lot of these degree symbols on the drawing. The only way I can fix is to update each one.
I tried copy / paste into Draftsite. Then copy /paste in SW, but did not help.
Anybody know a shortcut?
-rena
-rena
RE: Copy and paste autocad dwg into SW sketch - Degree symbol problem
Wonder if it can be done through the API? Search all the text for that character string and replace with <MOD-DEG>.
Cheers,
Anna Wood
SW2011 SP4, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
%%D is the internal way ACAD records the degree symbol in a text string. So DraftSight won't fix this.
I am surprised SW didn't fix this when importing the dwg file. Did you drag and drop or read the file in directly?
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
