Solidworks - Add degree symbol into Sketch Text on a Sketch in a Model
Trying to add the degree symbol into Sketch Text on a sketch in a model(see attached). The only way I have found to do this is using charmap.exe. Is there an easier way? I tried the alt codes, but can't get them to work.
-ren
-ren
RE: Solidworks - Add degree symbol into Sketch Text on a Sketch in a Model
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
Need to type the numbers on the number pad portion of your keyboard.
Joe
SW Premium 2011 SP5.0
Dell T3500 Xeon W3505 2.4Ghz
6.0GB Win7 Pro x64
ATI FirePro V5800
You can also select the More button for more symbols in the Dimension Manager as well.
See attached....
Cheers,
Anna Wood
SW2011 SP4, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
Cheers,
Anna Wood
You can check this with notepad or any other text editor by typing the alt code and switching the fonts it will show blank or as [] for fonts it is not included for.
Michael
I am surprised that SW doesn't include a button allowing you to add symbols in this feature, perhaps it will be available in a future release.
-ren
Alt 0176 °
Alt 0177 ±
Alt 0186 · <-- Middle dot, but I'd like to find a bigger one so it shows up better.
-Kirby
Kirby Wilkerson
Remember, first define the problem, then solve it.
• - that good? - or is that too small too? Alt 0149
SW Premium 2011
64 bit SP4.0
Intel Xenon X5650 @2.67GHz
2.66 GHz 11.9 GB of RAM
Special symbols - use charmap.exe
≤ alt8804
≥ alt8805
° alt0176
± alt0177
ø alt0248
Ø alt0216
• alt0149
solidworks dimension balloons:
add a balloon by using the Modify Text tool on the dimension text. Add the following to the dimension:
<C#-1> for a Circle
<S#-1> for a Square
<T#-1> for a Triangle
The "1" can be replaced with any number you desire, there seems to be a two digit limit.
Special ACad text characters
Control code Function
%%o Toggles overscore mode on and off.
%%u Toggles underscore mode on and off.
%%d Draws a degree symbol (º).
%%p Draws the plus-or-minus symbol (±).
%%c Draws the circle diameter symbol (Ø).
%%% Forces a single percent sign.
%%nnn Draws special character number nnn.
\L<> Underline
-Kirby
Kirby Wilkerson
