Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...Just a quick note to say, "THANKS!" for these forums...The site is very well layed out and easy to use. Thanks for bringing us together - we need each other."
Geography
palopjay (Mechanical)
18 Nov 11 6:35
Hi everyone.
I need an explaination for an issue i find using NX 6
I Use same shared License on 2 different workstations. First PC is Workstation out of my Studio. Second one is my workstation.
Using client PC, when i use the "show component in view" command, in drafting, i can select elements from ASSEMBLY NAVIGATOR, after clicking on selection tool over the list of hidden component.
This one not appear on my own pc. I can only select components from List in "Show components in view" window.
Can anybody tell me how to set this command for selecting from ASSEMBLY NAVIGATOR?
Version of NX6 are the same (my client gave me upgrade files for the last release)
Paolo Giacobbi
23 Nov 11 4:00
I take a screenshot for each selection tool.
Images at following links. You know the way to have this "selection button" in component selection?
Thanks.
Paolo Giacobbi
Without Selection button:
http://files.engineering.com/getfile.aspx?folder=af407dd5-2bf3-4b84-96c5-2c972e266ef2&file=ShowCompInView.jpg
With Selection button:
http://files.engineering.com/getfile.aspx?folder=5cee348c-686f-4ca6-ab97-ef52c0b3df2d&file=ShowCompInView_FULL.jpg
JohnRBaker (Mechanical)
23 Nov 11 11:11
While in Drafting, make sure that Assembly Modeling is toggled ON, which you can do from the Start menu.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
24 Nov 11 7:31
Thanks for the reply.
Unfotunately is not the way to solve my problem.
That's also becouse without Assembly ON, I could not use the command "HIDE/SHOW COMPONENT IN VIEW".
Differences are only in "SHOW COMPONENT IN VIEW" command usage. The button appear in second screenshot i posted last time.
The "SELECT COMPONENT" button let me select from Assembly Navigator,  (or on sheet) the component i want to show in a view. Is not a problem in UG usage, is only an "upgrade" of user interface, that don't forces me to look up and down the "Hidden component" list.
Paolo
24 Nov 11 11:45
Are you sure that you're running NX 6.0 on BOTH workstations?  I cannot under any conditions show what you call the 'Full' menu using NX 6.0, but it's there when I'm using NX 7.5.
John R. Baker, P.E.
Industry Sector
Cypress, CA
6 Apr 12 10:52
Thanks to you JohnRBaker, you are right. Siemens implement some part of 6.0 release for the Company I drawn for. Is not a standard tool, I think is a trial mode for Siemens to test new features for future releases, adding features to old versions of Unigrphics used by worldwide operative companies.
After this, I found a limitation using this "pimped" version of unigraphics, and I want to know if anybody can help me to correct this annoying issue i found everyday, during I use Routing Mechanical .
everytime I use "make corner" in Routing mechanical, It  shows  me an error. Log file tells:
&MACRO MENU, 0, UG_ROUTE_ASSIGN_CORNER UG_GATEWAY_MAIN_MENUBAR !
UNDO_UG: Recyclable status of mark 1453  set to False
*** EXCEPTION: O/S ERROR: signal  11 in line 1725 of F:\workdir\reference\NX605_3\src\syss\error\ind\error.cxx at Fri Apr 06 15:48:30 2012 W. Europe Daylight Time
+++ General Fault Exception
[ 1] 00002068D920                                                              (libsyss)
[ 2] 00002BB2E788                                                              (librout)
[ 3] 00001635024D                                                              (libroutcomp)
[ 4] 00003AFE8143                                                              (libuifw)
[ 5] 00001634C6CB                                                              (libroutcomp)
[ 6] 00003B00F0B2                                                              (libuifw)
[ 7] 00003B00F897                                                              (libuifw)
[ 8] 000020B072CA                                                              (libugui)
[ 9] 00003A269C26                                                              (libroutint)
[10] 000020976780                                                              (libugui)
[11] 000020976A11                                                              (libugui)
[12] 000020A0F0BD                                                              (libugui)
[13] 000021B17BA8                                                              (windowsui)
[14] 000021B18173                                                              (windowsui)
[15] 000020A0F3F0                                                              (libugui)
[16] 000020B4D677                                                              (libugui)
[17] 000020976D11                                                              (libugui)
[18] 00003A25AB26                                                              (libroutint)
[19] 00003A25C078                                                              (libroutint)
[20] 000020257B8D                                                              (libuginitint)
[21] 000140003521                                                              (ugraf)
[22] 00014000201A                                                              (ugraf)
[23] 000140006921                                                              (ugraf)
[24] 000077D596AC                                                              (kernel32)
>>>> O/S ERROR: signal  11 caught in file "F:\workdir\reference\NX605_3\src\routcomp\no\ind\RoutingUI_CornerTypeUI.cxx" at line number 139
>>>> O/S ERROR: signal  11 caught in file "F:\workdir\reference\NX605_3\src\uifw\no\ind\uifw_definitions.c" at line number 2592
>>>> O/S ERROR: signal  11 caught in file "F:\workdir\reference\NX605_3\src\uifw\no\ind\uifw_definitions.c" at line number 3416
>>>> O/S ERROR: signal  11 caught in file "D:\workdir\Patches\nx6053_patch\src\ugui\no\ind\uigblfunc.c" at line number 464
>>>> O/S ERROR: signal  11 caught in file "D:\workdir\Patches\nx6053_patch\src\ugui\no\ind\uigblfunc.c" at line number 389
>>>> O/S ERROR: signal  11 caught in file "D:\workdir\Patches\nx6053_patch\src\ugui\no\ind\uigblfunc.c" at line number 276
>>>> O/S ERROR: signal  11 caught in file "F:\workdir\reference\NX605_3\src\rout\ui\ind\ui_route.c" at line number 1436
&MACRO FOCUS CHANGE IN 1
&MACRO MESSAGE_BOX -2, Error recovery completed for the following error:
&MACRO MESSAGE_TEXT  Internal error: memory access violation
&MACRO MENU, 0, UG_HELP_SYSTEM_LOG UG_GATEWAY_MAIN_MENUBAR !
Nx 6 is started using an external link that use remote library (stored in a server in main seat of company) for component to insert using routing mechanical.
Other information: Same startup link, used in main seat of company, run without issues. This problem appear only in remote use.
There is something wrong in configuration of this edited version of nx6, can anybody help me find and correct this problem?
Thanks a lot.
Back To Forum
Close Box
Join Eng-Tips® Today!
Join Us             Close
