Time history analysis
I am running a time history analysis (a record of a ground motion) through my building. How do I combine the effects of time history to the effects of gravity loads (i.e. dead and live loads) so that I can check the adequacy of the structural elements? Do I combine linearly the gravity loads to time history in the Load Combinations? Or can time-history analysis include the effects of gravity loads? If so, how is the analysis result used in the Steel Design module of the program?
Also, a ground motion record has accelerations recorded in both X and Y direction. Do I include both using "Load Name" when I define "Load Case Data"?
Thanks.
Thanks.
RE: Time history analysis
You define your ground motion record as a time history function. SAP2000 can read a text file. You can have earthquake acting in 1 direction or multiple directions to simulate quake acting at an angle.
