Identification symbol text
it's possible obtain the result as the image attached ?
Thank you...
Using NX 8 and TC8.3
RE: Identification symbol text
when I add identification symbol manually, it's possible that the number is correct without to select each time the part list and make with the RMB 'update part list' command ?
Thank you...
