Can Flange Bolts/Studs and/or Nuts be Reused After Replacing a Gasket?
If you have a flange assembly and replace a gasket can the flange bolts/studs and/or nuts be reused in the new assembly?
Assume stainless material when using a spiral ring gasket and raised face flange.
RE: Can Flange Bolts/Studs and/or Nuts be Reused After Replacing a Gasket?
