Pipe Bending & Pipe Size.
Is  pipe  bending  for  atmospheric  pressure  pipe line allowed  as  per  ANSI  standard allowed.  The pipe line size is 25 NB [1"],  Sch 40.
Also  as  per  standards what  is  the  schedule  of  pipe  required  on  the  discharge side of  pumps  for  a discharge  pressure  of 45 kg/cm^2
RE: Pipe Bending & Pipe Size.
The pipe schedule required is a function, in addition to the design pressure and temperature, the size you require, the code the pipe is to be designed to (in NA, B31.1, B31.3, B31.4 or B31.8 are the most common) and the material of construction.  Your question can not be answered.
