Add fixture to holes pinned together by a pin with a smaller diameter
Basically I have a large assembly with several pieces pinned together. Its a long hanging track that bows do to the difference in diameter of the pin and the hole. Each pin is 1/8" smaller than the hole its going through. I designed a plate to go between the track pieces to fix the bowing but I'm not sure how to accurately add a fixture to allow for this wobble room and run proper FEA to see the forces applied to the plate and subsequently transfered to the side of the track under compression.
Thanks for your time and help.
RE: Add fixture to holes pinned together by a pin with a smaller diameter
You may also get better responses in the SolidWorks Simulation forum.
-Dustin
Professional Engineer
Pretty good with SolidWorks
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
