is necessary grounding CT without connection?
You have CTs of power system with secondary windings without the use. So you have to short-circuit them.
Question: do you have to ground them either?
RE: is necessary grounding CT without connection?
Yes.
Why? Is there some standard?
If not grounded, the secondary will tend to capacitivily couple to the primary and rise to primary voltage. A real safety hazard.
davidbeach,
do you mean that with capacitive coupling , there will be transfer voltage from primary to secondary?
Yes.
All CT secondary windings need to have ground reference without exception.
Scottf
I am just receiving a drawing of CT connection for governor.
Each phase-CT is connected to phase current CT channel of governor digital system.
 It is not a three-phase Y-connection(3Ph+1N wiring).
They are connected completed independent.((2+2+2=6 wiring).
There is no ground for neutral because there is no neutral.
Each pair of wire are shielding , with the shelding grounded.
Is this an exception?
Experts,I have some reservations.In CT( 66kV and above) the primary turn is fully insulated and provided with an external earth shield and earthed.The secondary winding over a toroidal core is placed concentrically to this shielded primary winding.Hence the transferred voltage to secondary due to capacitive coupling may be nil or negligible.
In power transformers, there is a similar case.When stabilising tertiary( unloaded) with all the three terminals are brought out,it is recommended to earth one corner of the delta tertiary.This is done just to drain away the charges on shut down otherwise some one climbing over the transformer tank soon after shut down may get a nasty shock on touching the tertiary terminals.
