Silicone adherance to Aluminum
Dear All,
I'm working on the design of a sealed box to encapsulate some electronics, my plan is to use silicone in the perimeter to seal the lid. I wonder if the geometry of the edge of the box have influence in the adherance of the silicone, this will be a die cast part, or if I should only focus in how clean the surface is mantained. Please if any of you could give me a hint where to do some good reading or can share his/her experience it would be very appreciated. Thanks
PS. This is my first thread ever! Please excuse me if I jumped too soon into the subject.
RE: Silicone adherance to Aluminum
We design sealed outdoor electronic enclosures, we almost never use silicone as the soul solution for sealing in electronics. I would highly recommend using a rubber gasket, or a foam-in-place product. Silicone is messy, hard to apply consistently in production and hard to maintain a consistent application. Also once the seal is broke or agitated it is hard to re-seal.
What IP or Nema rating are you going for?
StrykerTECH Engineering Staff
Milwaukee, WI
http://www.stryker-tech.com/
