Robot, Risa3d or another
My small firm is looking to buy some structural analysis software. In the past we've mostly dealt with temporary structures and residential, but are starting to get into buildings and other larger projects. Thus far we've done most calculations by hand, but to get into the larger projects we really need some sort of software.
After a little research it seems like Risa3D is most preferred, but can anyone convince me otherwise? Robot seems promising but it's hard to find opinions about it. The last post discussing Robot in any detail was from 2009. Does anyone use it? Has it changed since 2009? Any other suggestions?
RE: Robot, Risa3d or another
Mike McCann
MMC Engineering
I guess if it isn't very popular than it can only be a mediocre at best.
Thanks.
If you want an all around software, and you can only afford (1), I would suggest Risa. It will help you with those one off situations that always come up with small jobs. I would suggest buying Risa floor to help with copmposite floor design.
Hope this helps.
