How to model closed crack in beam in ANSYS
Dear people,
I want to put the crack but closed at the midspan of the beam with depth half of height and with wight all of beam. Can somebody save a file or explain how to do that.
RE: How to model closed crack in beam in ANSYS
What do you mean with placing the crack at the midspan of the beam? Can you be more descriptive of your specific problem?
Are you after the stress intensity factors? Are you trying to predict where the crack will go (KI, KII and KIII)?
If so, I have a set of instructions on how to do that in ANSYS than I can share with you.
Let me understand if this is what you are trying to do.
I hope this helps,
-Francesco
