Plug valve pattern for venting
In accordance with BS 5353, API 6D, API 599 etc. plug valves can be purchased as regular, short or venturi pattern. Which pattern is best to use as the last / throttling valve on a pipeline vent?
Thanks very much
MC
Thanks very much
MC
RE: Plug valve pattern for venting
My focus: Alloy Valves Duplex Valves Monel Valves Inconel Valves Titanium Valves Hastelloy Valves
The fluid is natural gas at 8MPa. Because the vent will be to atmosphere the valve temperature can drop to -50 deg C. The max. design temp is 80 deg C.
MC
