Cooling tower return header overpressure
Has anyone seen some kind of overpressure protection on the cooling tower return header and/or restraint system? We had an incident in our cooling tower where the nozzle and the valve on the header separated on #4 cell (high header pressure)
Will
Will
RE: Cooling tower return header overpressure
I have seen open-ended degassing standpipes at the top of the return header risers, just high enough to provide the head required to put the water through the distribution valves feeding each cell. Difficult to overpressure a return header with that setup.
SNORGY.
It is relatively easy to drain back a cooling tower out of operation and open up opportunities for this sort of thing on startup. Check your start up sequence for pumps starting before valves open and that kind of stuff.
If the waterhammer is occurring due to "normal" closure of a MOV then the final 3% closure range should be slowed down .
Another item that sometimes causes overpressure of the circ water pipe is the belated recognition that there sometimes needs to be added an add'l pressure loss at the circ water discharge to ensure the nozzle at the condenser CW outlet does not operate under vacuum- as might happen if the final circ water discharge is at a lower elevation than the condenser- this sometimes is missed in the design phase and later field modifications lead to high piping system pressures and lower circ water flows than originally intended.
