Calcium Chloride accelerator
Typically we do not allow calcium chlorides in concrete as an accelerator - but on a recent project I was asked if they could use it (vs. a "non-corrosive" accelerator) since the slab was not reinforced with ferrous materials - used synthetic fibers.
I thought that there were other adverse effects on concrete beyond causing wire mesh or rebar to rust but I'm not sure I can recall.
Any thoughts on the use of calcium chlorides in concrete?
RE: Calcium Chloride accelerator
What about anchorages, embeds, steel studs in contact, etc.?  Every slab has some steel accessories which could be subject to accelerated corrosion due to chloride exposure.
Yup...what TX said!
That's what I thought.  I mentioned to the contractor that we still needed to shoot in the interior stud walls and that would be problematic with chlorides in there.
Why would anyone use chloride accelerators with the non-chloride options?
He indicated that the chloride option was $3/cu. yd. while the non-chloride option was $9/cu.yd.
I only ever permit CaCl2 for temporary structures...
Dik
JAE:
Wish we could get concrete that cheap here, even with the CC!
Mike McCann
MMC Engineering
Why are calcium chloride accelerators still available?  Having them in the plant means they may be used inappropriately...also, the synthetic fibres are just a marketing ploy.
Hokie... because they're cheap and they work well and have a long history of application.
They also have a few problems, too...
