how to run subroutine
Hallo!!!
Im totally new with Abaqus and I will really appreciate a bit of help...I am more or less able to work with the CAE or with easy input files...The problem came when I realised that I had to work with subroutines...Reading in some foros I saw that I needed the Visual studio and Fortran compiler..I think I download the right versions for my windorws version (windows 7)...I am still downloading the Fortran compiler...But, can somebody tell me how I can check if it works correctly??? I was thinking about running some examples that you can find in the abaqus manual..but can you tell me what exactly should I do???
by the way...I saw some usual soubrutines suich as Dload, Umat....can you tell me if these softwares already have them or if I should do something???
as you can see...im quite lost...thanks a lot for your help!!!
RE: how to run subroutine
http://www
open the Abaqus Command window (start -> abaqus -> abaqus command), then type
abaqus fetch job=umatmst3* (dont forget the *)
this will fetch the inp and the f file into your temp folder (or work folder - the folder you are currently in)
then type
abaqus job=umatmst3 user=umatmst3.f
if there is everything ok with the fortran compiler, this job should compile and execute. then open the odb in the viewer to confirm.
you can also run
abaqus verify -user_exp
to test the same thing basically.
