Mirror and/or Symmetry V5??
I have CATIA V5 data we recieved from an equipement supplier and I came across a design process I cannot duplicate.
There are 2 catproducts with the same part name with a different instance name. The result resmembles a copy/paste however one of the catproducts is a mirror image. When expanding the tree, the individual catproducts contain the same parts, geo. sets, etc.
If I create a new part under either catproduct the mirror image part appears under the corresponding catproduct.
How was this accomplished?
RE: Mirror and/or Symmetry V5??
Download the script center, it has a tonne of little things that will help your or guide you to the promised lands of scripting.
This script I speak of is found under the Product section and called Product symmetry
Limitations to this method:
R20SP6 step does not recognize this move. Iges does.
The product you mirror must be located around world 0,0,0 and NO rotations. You will create funny shapes otherwise.
Derek
Win XP64
R20/21, 3DVIA Composer 2012, ST R20
Dell T7400 16GB Ram
Quadro FX 4800 - 1.5GB
