Regarding Wavelink body........
If i wavelink the body in assembly, mass(wegiht) should be zero value. What is procedure to get..........?
RE: Regarding Wavelink body........
Hope this helps,
Jon
JHTH
NX 7.0.1.7 + TC 2007
I have tried with above procedure but the component will not select due to applied material Properties. If you want to do this procedure first remove material properties and it works......
