Material specification vs. material grade - how do they relate?
We are a spring manufacturer. We made springs to a customer's drawing but they are rejecting them. Their complaint is that we used the wrong material. Their drawing calls out "Music wire per QQ-W-470, spring temper, UNS G-10800, .0220 ± .0004 dia."
We ordered - and used - music wire per ASTM A228 (replacement for QQ-W-470) which defines the material's chemical composition. But as pointed out by our customer, the chemical composition of UNS G-10800 is different from the chemical composition prescribed in ASTM A228, as follows:
ASTM A228
Carbon: 0.70 - 1.00%
Manganese: 0.20 - 0.70%
Phosphorous, max: 0.025%
Sulfur, max: 0.03%
Silicon: 0.10 - 0.30%
UNS G-10800
Carbon: 0.75 - 0.88%
Manganese: 0.60 - 0.90%
Phosphorous, max: 0.04%
Sulfur, max: 0.05%
Silicon : "as required"
I'm trying to understand what, to me, is an apparent contradiction. That is, how can they specify music wire to material spec QQ-W-470 (now ASTM A228) that defines the material's chemical composition limits, while simultaneously specifying it to a UNS category that sets contradictory chemical composition limits?
I'm missing a critical element of understanding here and I don't know what it is, or who to go to for a clear explanation, or even how to frame a relevant question.
Any ideas or help?
ASTM A228
Sulfur, max: 0.03%
UNS G-10800
Sulfur, max: 0.05%
Any ideas or help?
RE: Material specification vs. material grade - how do they relate?
Do you have a material certificate for your ASTM A228 material? Looking at the above chemical composition comparison it is likely that your material falls within both ranges.
So far they are simply asking why we didn't make the springs out of UNS G-10800 material. At this point I need to open a dialogue with them to discover the scope of their complaint and discuss design requirements. I'm trying to gain insight and knowledge beforehand to be able to participate in an informed discussion.
I have a feeling they will change the material callout on the drawing, but in whose favor it will be remains to be seen.
I'd be interested to hear how your similar situation got resolved.
Yes, QQ-W-470 is cancelled, in 1985. The cancellation notice refers future procurement to ASTM A228. That much is clear.
And yes, we do have the material cert. While it's possible to produce material that conforms to chemical composition requirements of both ASTM A228 and UNS G-10800, the overlap range is pretty narrow and our material cert clearly shows the manganese percentage is too low to meet UNS G-10800. Dang!
My dilemma is that the UNS G-10800 grade of material consists of a range of chemicals that fall outside the ASTM A228 standard, not within.
To look at it another way, the drawing material callout consists of 2 requirements (ASTM A228 and UNS G-10800), each of which contradicts the other. This is sort of like a zen koan, 'what is the sound of one hand clapping?' in that it makes no sense to me.
Thus my continuing confusion.
Often people do the sort of thing that your customer has but there is enough overlap between the two chemistry that you can actually make the product.
Also sounds like you missed a spec review up front. You should not have taken the order with this requirement.
Plymouth Tube
TTFN
Chinese prisoner wins Nobel Peace Prize
You are both correct, we did miss the discrepancy during contract review and we should have caught it then (due diligence). But we didn't. Now here's the kicker...we have been making this same part for the same customer for over 14 years. Neither of us have 'caught' this until now.
Things change. <sigh>
No, they are specifying the raw material to the Fed spec and the UNS grade simultaneously (all in one breath, so to speak).
It's not the mechanical properties that are in question, it's the chemical composition.
Very frustrating...
So, was your material ever procured to UNS G-10800 requirements? If so, and they haven't had any problems, you might want to point that out.
TTFN
Yeah, this is an old drawing. Its initial release pre-dates the cancellation of QQ-W-470, so the QQ-W-470 spec was valid at the time the drawing was initially released.
So now I wonder, am I dealing with an issue where the material callout was valid at the time the drawing was released, but which is now invalid due to changes in the interim?
And no, we never produced using UNS G-10800. There is also the fact that there has never been a reported failure. I will stop short of reminding them that they also missed the material discrepancy for the past 14 years.
My opinion - it is not proper use of the specs, but if the material requirements DO overlap, then nothing is contradictory in the strictest sense of the word.
If you ask for a part to be red in one place and blue in another, that is a contradition. Purple would not be acceptable. Red with blue stripes would not be acceptable.
If you ask for a rectangle in one place and a square in the other, you're getting a square which also happens to fit the description of a rectangle. Not contradictory.
"What is the sound of one hand clapping?" Not as loud as 2 hands clapping, but it is still audible. Depends how many fingers hit your palm.
Customer is a huge conglomerate going through a corporate-level restructuring and improvement effort. Our specific customer is a former small subsidiary that is now under a larger umbrella and being absorbed into this new corporate culture, so they are scrutinizing everything.
Your illustration points are well taken (colors, shapes). A question I have, though, is how do we order material? So far our material suppliers are saying "one (red) or the other (blue), not both (red and blue)".
Or if your volume is big enough, write your own spec and order the min tonnage from mills.
I feel you should be able to find a solution to the current issue given your 14 yes of relation and no field failure. Technically it should be a OR between a228 and 1080.
I think this will end OK, with customer changing material callout on the drawing. My greater concern is towards our relationship, and how or if it will change.
TTFN
As far as ordering material goes, you can say "Material per ASTM 228 excpet chemistry must be per UNS G-10800".
Of course, it could be possible that things have gotten confused over the years. Do you have access to the QQ-W-470 specification that was active when the original drawing was produced? If you can get a copy, it may be useful to see if the chemical composition listed in the old specification matches what is now in the current ASTM A228. Is it possible that the old QQ-W-470 spec was loose on chemical composition and that the UNS callout was needed to insure the correct material was used? Obviously, when the QQ-W-470 was discontinued the drawing should have been revised to reflect the active specifications, but that didn't happen. All you can do now is to try to get the customer to use current specifications.
Regardless, you will have to negotiate with your customer to resolve this situation to your customer's satisfaction.
rp
Interestingly, the chemistry is very slightly different between the old QQ-W-470 spec and the current ASTM A228 spec, most noticeably for Manganese (old was 0.20% - 0.60%, new is 0.20% - 0.70%). So with the old QQ-W-470 spec there was no Manganese overlap to the UNS chemistry (which is Mn 0.060% - 0.90%), but the newer ASTM spec provides wiggle room (some overlap) for Mn.
I was hoping there might be someone in this forum with mill experience to explain how the two material callouts relate to each other (QQ-W-470 vs. UNS G-10800), and what would our PO need to look like in order to receive compliant material? So far our material suppliers have not provided such expertise.
But on the other hand, a range like 0.6~0.9 of 1080 is not the range that steel mills absolutly need to produce 1080. If they pay attention, they can control Mn in that range all day long. I had experience to order mill runs for many years and I can say that the variance of Mn is small within a batch of different heats.
1080 is a plain carbon steel and the only alloying element is Mn. If the steel mill is BOF, they can control it easier than a EAF mill as they have to literally add in Mn to a level versus EAF that they have to balance their different scraps to get the tight range for Mn. So possibly you have to pay a surcharge if you insist on 0.6~0.7 of Mn.
Hmmm...
Of course, we still have process issues to remediate, but those are already pretty much resolved. In the end, everyone is better and smarter.
