Foamed Concrete vs. Polystyrene Blocks
Any idea about the cost of polystyrene blocks compared to foamed concrete?
RE: Foamed Concrete vs. Polystyrene Blocks
On a volume basis EPS foam is probably the lightest and cheapest in sheets or blocks. XPS is a very common readily available and is far superior for most applications.
Foamed concrete can have variable properties.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
R value approx 1.5 per inch... and weights about 40 or so pcf...
Dik
