Tensile Strength of concrete
can anybody tell me a reference where I can get the tensile strength of concrete after 3 days of curing. thanks.
RE: Tensile Strength of concrete
Also, tensile strength is more variable than compressive strength. While there is a relationship between the two, in my experience I've seen the tensile strength be more variable.
I'm curious as to why this is important at 3 days. Are you concerned about direct tension or modulus of rupture for flexure?
You can also do a splitting tensile test on cylinders molded for compressive strength.
min steel ratio = fct3 / fy
fct3 = the principal tensile strength of concrete at three days.
anybody have an idea where to get this value? i cant find it here in the code...
For 30 MPa mix, ultimate tensile would be about 3 MPa and at 3 days, about 1.5 MPa.
These are rough correlations that can be found in most of the literature (for example, A.M. Neville...any edition)
hokie66, RE, BigH....check me on this!
In my experience the variations are higher than those for cylinders or pavers that are tested on at a controlled loading rate.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
