Adding Strainer
Adding Strainer
Guys I need some advice, as I posted here before about frequent fouling of our pre heat exchanger. base on my survey it turns out that adding strainer will be good enough. Im thinking of buying a bucket type strainers for upstream of Plate type heat exchanger. What are the possible problems I might face in future after installing this. At present exchanger is in bypass mode. A good advice plesae
RE: Adding Strainer
an upstream filter wouldn't harm, i guess...
RE: Adding Strainer
