read (input) file as real-time data
Hopefully this one is easy. I think this should be a no-brainer, but I haven't used LV extensively in quite a while... :P
I have a text file I want to read in to labview (I'm good there); but I want to read it in at, say, 200Hz, as if to simulate a real-time data stream. I'll be using my VI for real-time data reduction/display, and need to make sure everything is up to par.
Again, apologies for what I think should be pretty easy. Would the proper way be to read the data in, then maybe 'filter' it with another vi at 200Hz?
Thanks!
