Reinforcing Steel
Reinforcing Steel
Reinforcing Steel
Can someone post a *.dwg file that has reinforcing steel deformations.  I want to draw some dowels with the actual deformations shown.  It just has to be a short length and I will modify it for the various bar sizes.
Thanks, Dik
RE: Reinforcing Steel
Regarding the term deformations, are you referring to bends in the dowels?
Thanks, chicopee...
No, just the straight bars... problem solved... drew the first set of deformations and copied them for the length of the bar... then inserted them as a block... was using them to distinguish between tiebars and smooth dowels...
I was hoping that someone had already done that...
Dik
