Transparent undocked menus, WIN7 64bit/NX7.5
Anyone run into this.  When you undock your Assembly/Part navigator windows, and they are not the active windows they become transparent.  I figure this is a Win 7 'feature'.
But anyone know how to disable this?  I went into personalize, un-checked the transparent box and nothing.
Thank you.
RE: Transparent undocked menus, WIN7 64bit/NX7.5
Jackely,
This can be changed mid-session using NX  "Preferences, User Interface..., Layout, Enable Transparency", uncheck the box and either Apply or OK the dialog.
Regards, Joe
Go to...
Preferences -> User Interface -> Layout
...and toggle OFF the 'Enable Transparency' option in the 'Windows Style' section of the dialog.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum:   http://www.plmworld.org/p/cm/ld/fid=209
Thank you gentlemen.  I do appreciate it.
I had poked around, with windows display and inside of NX, but didn't go under User Interface.
Thanks again.
