Problem with ANSYS command line [yes/no] dialogues
I have input files that I would like to run from the Linux command line without using the GUI. I issue the command
ansys110 -g off -i inputfile -j jobname
However in my input file I also am using the MODMSH,DETACH command and during the input processing I get the message
"DESTROY ASSOCIATIVITY OF FINITE ELEMENT MODEL AND SOLID MODEL
*** WARNING *** CP = 0.280 TIME= 11:43:07
CLEAR, SELECT, AND MESH BOUNDARY CONDITION COMMANDS WILL NOT BE
POSSIBLE.
Should the MODM command be executed? [y/n]
*** NOTE *** CP = 0.290 TIME= 11:43:07
*** The MODMSH command aborted *** "
It executes and automatically chooses no and then kills my simulation run. When I run it through the GUI it automatically selects yes and runs just fine. How do I tell it to select yes or suppress the warnings when not using the GUI?
POSSIBLE.
RE: Problem with ANSYS command line [yes/no] dialogues
CODE
I would also include a /BATCH command at the top of the input file.
See FAQ569-1083: Asking questions the smart way on Eng-Tips fora for details on how to make best use of Eng-Tips.com
