Nailboard view goes missing on edit. - no update - wire id's
i have 2 questions re: nailboard drawings.
When i try to use the edit button on the nailboard tab in order to add dimensions to the harness sketch. the environment changes and the harness sketch disappears. This makes it hard to dimension using the harness dimension button.
can someone tell me what i am doing wrong please?
Secondly, i have modified the harness in the model and then saved the assembly. Why does my nailboard drawing not update after the save. (it recognizes that changes have been made) Deferred update is set to off. The nailboard drawing is useless if the updates are not automatic.
......alright i have 3 questions......i want to show the wire id near the stubs. i displayed properties but only 1 of 2 wire id's showed up (twisted pair). Has this got something to do with pick order? How can i get INV to display each wire (id) number?
