Deleting lines in a sketch
Just moved up to NX7.5, and I'm coming across several models (created in earlier versions) in which I cannot delete lines that are in a sketch unless you first delete any solids created from the sketch.
I have tried creating a new sketch in the same model, sweeping a body from it, and I can then delete elements out of the sketch with no problem.
Why are the old sketches mis-behaving?
RE: Deleting lines in a sketch
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
Then I remove those reference lines in the sketch after the feature regenerates, if I need to.
