Using an electromagnet to disengade a permanant magnet?
First post here, I am hoping some kind soul will be able to help me with solving a problem that I have.
I am a structural engineer specialising in structural glass.  I am setting out to test some glass samples for impacts  and for this I am required to drop a steel ball of approx 1kg from a height of 4m.
I am proposing to use an electromegnet for the release mechanism, but there are some obvious dangers that I need to take precaution against.
What I am considering, is to use a permanent magnet to support the steel ball, and than have an electromegnet to disrupt the magnetic field, causing the ball to drop.  This ensures that if there is a power failure, the ball will remain safe.
Seems like a nice idea, but I am not knowledgable enough to know for sure that it is possible.  Any help would be greatly appreciated.
I have attached a sketch to show the arrangement I am proposing, and links to what I believe will be suitable parts.
Ring magnets.
http://e-magnetsuk.com/magnet_products/neodymium_magnets/ring_magnets.aspx
Electromagnet.
http://www.ebay.com/itm/12V-DC-3W-Electric-Lifting-Magnet-Holding-Electromagnet-Lift-2-5Kg-Solenoid-/190586717598?pt=LH_DefaultDomain_0&hash=item2c5fda859e&afsrc=1
RE: Using an electromagnet to disengade a permanant magnet?
What you have sketched will not work. There used to be a product called FailSafe that did what you want. They don't seem to list it on their website any more. A PM product called Safehold can be motorized to drop the object. Alternatively use a battery backup to power your electromagnet.
Mike
A simple block magnet, with poles oriented horizontal.
Steel pole pieces that run down each side of the magnet and are about 2/3 of the ball diameter apart.
You don't want a real strong magnet, just to hold the ball firm.
A ferrite magnet should be fine.
Coils wrapped around the two pole pieces and wired so that the field that they produce opposes the PM.
A simple pulse should cause release.
Plymouth Tube
