Duplex Satinless Steel with CS
We have to make weld between tube and tubesheet. Tubes material
SA-789 UNS S31803, tubesheet material is SA-516-70, welding process shall be GTAW.
Would ER309LMo be a good option? Any suggestion please?
Thanks for any favor.
Nasir
Welding Engineer
DESCON ENGINEERING LIMITED
PAKISTAN
RE: Duplex Satinless Steel with CS
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
ER2209 is used to weld duplex to duplex, we never used it to weld duplex to carbon steel. Do you have any experience?
we have to make weld between duplex and CS.
Nasir
Welding Engineer
PAKISTAN
Welding Journal, February 2007, pp51-s - 54-s
Welding Journal, December 1998, pp477-s - 487-s
Steve Jones
We have used ER2594 to make the weld at the request of the Owner/
Operator (large Petrochemical company).
So far no problems but the weld has only been in service for a little over a year. Our "standard practice", when no direction is provided by the Owner/Engineer, is also to use ER309LMo depending on service temperature (normally service temps are below 350F).
