Question about C=0 Zero Acceptance Number Sampling Plan
My company is using the following sampling table based on Nicholas Sequigla's Zero Acceptance Number Sampling Plan:
ht
My question is where do the sampling size numbers in the table come from? What statistics equation/formula is used to arrive at these sampling size numbers? How is this statistics formula used to get these numbers?
I have read that the numbers may come from Hypergeometric distribution, Poisson distribution, or Binomial distribution. I have tried applying these formulas but still do not understand how they got the numbers in the table.
For example, the table states that for a lot size of 51 to 90 and AQL of 1%, the sample size is 13. My question is how was it determined that 13 is the sufficient sample size? There must be a statistics formula used to calculate this 13.
If someone can proivde me with a thorough explanation, I would truly appreciate it.
RE: Question about C=0 Zero Acceptance Number Sampling Plan
http:
If you are using the c=0 sampling plan, then you really should have buy Squeglia's book to cross reference.
