Creating separate drawings for frame generated items
Hi All,
I can modify Frame Generated RHS's with cuts, holes etc whilst in an assembly (iam) file with no problems, trouble starts when I want to produce separate drawings for each item in the frame.
If I seek out the frame assembly folder and open up individual frame parts they come into the drawing at the correct length but do not have any of the modifications present.  The only way I have found of doing this is to open a frame item from the assembly/frame folder and make the necessary modifications there.
Is there another/better way?
Best Rgds,
Dave R.
