Welding Shear stud for Composite Beams
Can someone tell me what AWS D1.1 says about field welding of shear studs for composite beams? A job we are working on the contractor has fillet welded the studs to the beams.
Thanks.
Thanks.
RE: Welding Shear stud for Composite Beams
Also there is minimum size of fillet required depending on the diameter of the stud this is located in table 7.2
Not a very technical procedure, but it works per CWI.
Mike McCann
MMC Engineering
