Light Bulb continuity
Dumb old structural here with an $8.00 Radio Shack tester.
I would have thought that a light bulb (known to work) would show continuity - but it doesn't. IS the resistance too high??
Or do I just not know what I am doing?? Has happened before.
RE: Light Bulb continuity
The resistance of a cold light bulb is much less than you'd calculate by R=P/V^2 (where P = watt rating and V =voltage) as a result of temperature coefficient of resistance.
I don't know what the cutoff is for your tester, but I'd have thought you'd see an open.
Does your tester allow you to check resistance?
(2B)+(2B)' ?
Dan - Owner
http://www.Hi-TecDesigns.com
A typical continuity tester might reject anything even close to 10 ohms: http:
Obviously, there are others where 2K is acceptable: htt
And others that are in-between at 400 ohms: http:/
One Radio Shack instrument buzzes at less than 50 ohms: http://sup
I don't know what kind of tester you have, but presumably, you're just using the continuity position of the ohmmeter function, in which case, you should just measure the resistance directly.
TTFN
Chinese prisoner wins Nobel Peace Prize
Just trying to find a fault in a circuit.
THANKS for your help!!
Describe the light bulb in more detail. Is it household, or is it a small flashlight sized bulb.
Why are you testing a light bulb if it's known to be good?
It must be a resistance thing. Again - THANKS!
40 watts at 120 volts gives R = 360 ohms
Typical tungsten filaments will undergo a 10:1 to 12:1 increase in resistance from cold (unlit) to hot (lit), so a typical cold/unlit resistance might be 30 to 40 ohms.
Since we (and you) know nothing about the "tester" and its performance specifications, discussing it further seems rather futile.
TTFN
AGREED - just thought a light bulb would show continuity - NOW I KNOW better. Obviously a resistance thing. Now I can go out and try not to kill myself and come back with some other dumb questions.
TTFN
