Modeling an RMU in SKM
Greetings everybody
How I can model a MV Ring Main Unit in SKM?
Thanks in advance.
RE: Modeling an RMU in SKM
I don't use SKM, but a ring main unit is just two ring switches that can either be open or closed, and a tee off circuit breaker or fuseswitch. That shouldn't be difficult to model.
Marmite
Hi burntcoil
If by SKM you mean Powertool for Windows then there is no specific RMU device. I just use two isolators/links and a breaker or fuse as appropriate as mentioned by marmite.
Regards.
