Cold weather effects on concrete
I have recently started doing concrete work in a cold weather state where winter temps frequently drop below freezing. Im trying to determine through someone with competent knowledge the difference between 3/8 inch pea gravel aggregate and 3/4 Inch hard rock mix designs. Is pea gravel appropriate for cold weather with a properly engineered mix design?
