program to insert blocks on polyline verticies
I'm looking for an editable program LISP (preferably) or VB that will place a block at every vertex of selected polylines.  Anything out there?
RE: program to insert blocks on polyline verticies
Thanks.   I should have Googled before posting.  I got this one:
; Insert the block Weld at each polyline vertex
(defun c:wb ()
(setq
 plobj (car (entsel "\nSelect Polyline: "))
 inc 0
 (while (<= inc (vlax-curve-getEndParam plobj))
  (command
  "_.insert"
  "weld"
  (vlax-curve-getPointAtParam plobj inc)
  (setq inc (1+ inc))
That appears to do the job with a minimum of code.
You might want the code to disable then re-enable osnaps; in some cases/zoom levels the insert point might go to wrong location.
If a UCS is active, that too could caue errors.
