weishaupt boilers of oil
I HAVE A BOILER ON WHICH I USED BURNER OF WEISHAUPT 2250 KILOWATT
I KNEW THAT IT IS 2 MILLION K CAL THAT MEANS 2250KW=2 MILLIONS CALLORIES BUT I WANT TO KNOW THAT HOW I CAN CALCULATE THE STRUCTURE OR TUBE SIZE ON WHCIH MY BURNER IS MOUNTED THAT IT ALSO SUPPORTS AT 2  KILO MILLION CALORIES IS THERE ANY FORMULA OR ANY WAY TO CALCULATE FOR THAT I AM USING OIL IN THE TUBES OF BOILER WHICH WAS HEATED AND WE GOT 260 C TEMPERATURE AT OUTPUT.
RE: weishaupt boilers of oil
1.  DON'T SHOUT!!!!!!!
2.  Please ask a native English speaker to help you rewrite your message, with punctuation, so that we may have a clue where each sentence begins.
3.  Thank you.
Mike Halloran
Pembroke Pines, FL, USA
I JUST WANT TO ASK THAT I HAVE A OIL BOILER  MENTIONED ON ITS DOCUMENT THAT IT WILL PRODUCE 2 MILLIONS K CAL HEAT ENERGY.
IT CONSISTS OF 3 TUBES OF (M.S) METAL INSIDE IT.WEISHAUPT BURNER IS USED ON THAT RATED AT 2250 KW.I WANT TO KNOW THE METHOD TO CONFORM THAT DOES IT SUPPORTS 2 MILLION K CAL OF HEAT OR ABOVE.
THANKS
DON'T SHOUT!!!! means for you to turn your Caps lock off and type in lower case.  All upper case is difficult to read.  If you want help, folks have to read it.
rmw
It will have some efficiency.  Certainly it will be less than 1.  It means not all the heat goes into it.  Some of it will be lost up the stack.  So it's capacity should be greater than it's rating by it's efficiency.
Isn't it annoying when only pronouns are used?  It's really hard to tell what is the subject of it, isn't it?
Please use proper nouns.
If you go on line and check out Weishaupt Models "G", "GL" and "RGL" manual as it contains detailed descriptions which may describe what you want to know.
I didnt get the reliable answer i knew that there's a way to calculate. For that there is a procedure throgh which we can easily get the exact capacity of the coil that. I didnt find it any where some peoples have knowledge about that but they didnt share with others.
i have found a clue for that we should know the specfice heat capacity of the material that we are going to burn.
regards
khawar hussain
You didn't get a reliable answer because you haven't asked a reliable question.
Please try to find someone to help you phrase your question better.
