SA-36 Temperature / Yield
I am trying to locate (thus far unsuccessfully) data that states that A-36 material is good for up to 1300 degrees. This is not in a pressure environment; it is for an exhaust vent. So far everything that I've come across says that it is only good for 750 - 850 F before creep kicks in. If that is the case, then what would the yield be at 1300F?
Thanks in advance.
Thanks in advance.
RE: SA-36 Temperature / Yield
Source - report on fire exposure of structural steel below
http://
Your main concern will be severe oxidation at 1300 deg F for carbon steel.
