Wildfire 3 in Windows 7 Home?
thread554-265981: Windows 7 and Wildfire 3.0
In the referenced thread, 'looslib' says that Wildfire 3 should work in Windows 7 "as long as you are NOT running the home version of Windows...". Why can it be run on the professional version of Windows, but not the home version?
RE: Wildfire 3 in Windows 7 Home?
If you can find ALL the registry settings and added sub-programs and enable them, then it should work in Win7 home the same as Win7 Pro.
It actually may work in Win7 home without doing anything, but PTC does not certify Win7 home as a valid OS.
Ben Loosli
The actual identifier used by the license is the Ethernet Card's Physical address which you can find by doing the following.
1) Launch Run command, Start > Run or Win & R
2) Type cmd Enter (this will launch the DOS shell cmd.exe)
3) When the command window comes up type
ipconfig /all |more
(The info you need will display first, "|more" shows resulting info in multiple sections instead of all at once,Hit space to see more )
You'll need to request a new license for each machine or Ethernet Card you use.
The physical address reffered to as is made up as 12 alpha-numeric characters in six groups of 2 sepatrated by -
Physical Address. . . . . . . "??-??-??-??-??-??"
This will be shown in the license file typically called license.dat and located in the text\licensing\ folder
C:\Program Files\ProENGINEER Install Directory\text\licensing\license.dat
PTC_HOSTID=??-??-??-??-??-?? will be included in the license.dat file and if that is not the Ethernet Card's ID the license will not work.
You should be able to resolve this by calling Tech Support or your Software Reseller.
Michael
