Socket welding underground threaded pipes
Hello all,
would there be any problems to watch out for is socket welding threaded pipes to be buried?
RE: Socket welding underground threaded pipes
My two cents
StoneCold
So it is generally better to socket weld it (without threads) right?
ALSO
do I have to worry about corrosion coating if this is for dry gas service or oil/condensate. What about produced water.
FINALLY
B31.3 made some confusing comments, can you please help me clarify
in the latest version of B31.3
Para 311.2.5: it says use it but avoid corrosion and sizes > 2"
Para K306.1.2: it says don't use it for fitings, bends, and branch connections
Para K308.2.2: it says don't use it for flanges, blanks, facings, and gaskets
Para K311.2.3: it says don't use it for weld joints
It almost sounded like use it but don't use it...can anyone help clarify the "not permitted" parts please
Thanks a lot.
Unless Crevice Corrosion is a problem in your service [rare] there is no preference between socket-weld and butt-weld fittings, in smaller sizes.
3"NPS and larger socket-weld fittings are available, but unless it is impossible to hire a decent pipe welder, buttweld those larger sizes. There are arguments for both socketwelding and buttwelding 2"NPS. I currently prefer buttwelding.
Threaded pipe can be readily "backwelded", and turned into a socketweld connection. But it is expensive and time consuming. If this is an existing threaded connection, it will have to be disassembled and both the male and female threads cleaned of all the pipe dope [thread sealant]. Then all malleable iron fittings must be discarded and replaced with forged steel. Then the weld is made, and ALL the exposed threads must be 'buried' with weldmetal so bring the pipe back up to full wall thickness.
Just buy Class 3000 socketweld fittings made to SA-105. Socketwelding is actually faster than threading, if you have a good pipefitter and a good welder.
Depending on a whole bunch of things that I don't fully undestand you may need cathodic protection too.
could you please explain how the back welding would cause "an inherent stress riser along the edge of the weld - the thread root" please.
Thank you.
Any exposed threads have a sharp, 60° included-angle stress riser at the thread root. Bad thing to have.
