Male NPT into a Female NPSM
Does anyone know how far a 1/2" MNPT will thread into a 1/2 FNPSM when it is hand tight?  (note: this arrangement is typical of bi-metal thermometers threaded into thermowells.)  I can't find a chart/table which shows this information.  I could just try it, but I do not have the parts.
RE: Male NPT into a Female NPSM
Figure it out from the taper.  Calculate the distance to equal diameters, female ID to male minor where interference begins.
Ted
http://www.mcmaster.com/#straight-thread-pipe-adapters/=exjh0n
try looking at these adapters.
I used to use some Ingold fittings that are 1 1/4" NPS threads male, and I just use 1 1/4" NPT caps to close them.  Ended up getting about 1.5-2 turns on it.  But that was enough, with some teflon tape, to seal them.
