Which spring washers to avoid Creep
Hello everyone,
There appear to be several types of spring washers out there:
Belleville Washers: ht tp://lh4.g gpht.com/_ EhOQGW2GHB g/Sngf58FY 0AI/AAAAAA AAHuA/7XVY i9spfRo/Be llevilleSp rings2.gif
Cut washers:
h ttp://www. shop4faste ners.co.uk /acatalog/ shop4faste ners_squar e_section_ spring_was hers_stain less_steel _a2_a4.jpg
Wavy washers:
http://ww w.sdp-si.c om/estore/ CoverPg/Ha rdware/Wav e_Spring_W ashers.jpg
Do you guys know which type would be best to use when joining 2 Carbon Fiber structural parts while minimizing creep and stress relaxation?
Thank you in advance for any comments or feedback.
Cheers,
Christopher
Cut washers:
h
Wavy washers:
http://ww
Cheers,
Christopher
RE: Which spring washers to avoid Creep
Either option will increase the contact stress due to the small contact area, unless you use a flat washer between the springs and the carbon fiber part.
They don't really "minimize" creep or relaxation. If properly sized and things are properly tightened they can compensate for some amount of fastener preload loss due to creep and relaxation.
They are more expensive than internal or external toothed "lockwashers"... which don't really work at all.
Ted
