Software for Settlement Calculation
Would somebody be kind to let me know a software for settlement calculation other than Unisettle. Unisettle is definitely a good software but I found it difficult to understand and am more in favor of SLOPE/w type software. Thanks.
RE: Software for Settlement Calculation
http://www.geologismiki.gr/Products/SteinP.html
www.FoundEng.com
From my experience with that method, it seems to work well, mainly because the actual job experiences conform quite well to the predictions.
It is written up in an old ASCE paper 2195 SM4 of the Soil Mechanics and Foundation Division, August 1959. The reviewers in February 1960, include Ralph Peck (who po-pooed it) but two discussors from California DOT made a study of 20 cases where settlemnt was measured and found no more than10% error in 70% of the cases, with maximum error of 40%, all in sand.
If you can't find the paper or the book, I'll see if I can get the basic info to you via these threads.
There also are some later papers comparing several settlement methods, including this one. I seem to recall ASTM also has some adoption of this Hough Method.
Thank you for the feedback. I do not have the book but will search for it.
Am looking for a tool to calculate BC and settlement without getting into research as seems research on this subject is endless.
I also recommend Hough's book. While it is old, there are a lot of basics that are simply covered, with fairly good examples.
Thanks. I have referred to Das, CFM, NAVFAC, Tomlinson, and some web based formulations but am a bit tired of comparing those and going to the most onerous answers which may not be the right thing to do. Therefore I am looking for only one reference that could give me some reliable data and the rest as you suggested would depend on the field data, how they were obtained and engineering judgement (intuition). I assume the Hough's reference could be one and will go to find it. Thanks again.
I agree with oldestguy...a spreadsheet is sufficient. As for references...take your pick. Hough, Peck, Terzaghi, Sowers, Seed, Bowles, Lambe or Das...all have their ideas and all are probably right in some context...the problem with geotechnical evaluation is picking the context....it is varied and changes greatly with locale and location...sometimes within a few feet. Granular coastal plains soils with a high water table react differently than arid granular soils. Clays can be so varied that you have difficulty predicting the activity across a site.
Good luck.
