AWS D1.1 welding question on partial pen. vs complete pen.
Ok Guys, I have a question and am hoping you guys can help. The question results from me doing something stupid, I want to see what you guys think. If I ultimately have to redo the weld joint I am willing to take responsibility for my mistakes and accept that, however I want to make sure I have a full understanding of what is required before I make a blanket statement that I need to redo a weld.
Here is the issue, we are welding a 12" x 20" piece of hollow stuctural steel (5/8" thick) to a 2" thick plate that is 4' x 4' to create a pipe support for a steam line.
The design engineer for the structure is saying that in order to carry the loads that were determined by the stress analysis, we need to be able to have a full penetration weld. (as a disclaimer: this individual by his own admission is not a welding engineer. His position is the he wants to be absolutely certain that he can count on 100% of the cross section of the tube as load carrying. ie... there are no break on discontinuities to create stess concentrations along the weld joint)
According to AWS D1.1 this is a T or Corner joint. When reviewing the pre-qualified WPSs in D1.1 none of them allow for a simple open butt joint with a 6010 root. The only thing that I can come up with is either a TC-U4A joint (which would require backing) or a BTC-P4 joint (with a 1/8" land.) This is the rout we went. Rather than try to secure backing strips I felt it would be easier to weld with the land as a partial penetration joint.
Given the very small land used (1/8") is it still acceptable to take credit for the entire 5/8" as being welded from the tube steel to the plate. My opinion would be yes, because as you weld the first passes (7018 rod was used to weld this,) you would have a good amount of penetration down into the base metal in order to join them together. I know 7018 is considered a moderate penetration rod, but I think you would still break down the metal along the land and create a good fusion along the root of the joint. I dont think it would be a 100% "X Ray quality" weld, but I do think it would acceptable in regards to the load carrying capacity of the support.
What would you guys consider on a joint like this? Would the partial penetration be acceptable or should I go back and redo the joint to make it a complete penetration. Any refences in AWS D1.1 would be helpful as well.
Please let me know if any further information is needed.
Thanks in advance for any help.
Rob
RE: AWS D1.1 welding question on partial pen. vs complete pen.
I accidentally posted this in the wrong forum, moderators can you please delete? I have posted this in the AWS welding forum.
Sorry for the inconvenience.
This forum got quite a lot welding experts, I am not. I think you are fine to leave it here :)
What do your calc's show for a simple fillet weld of that size?   That is, what do you gain from a fillet weld compared to a full-penn weld of 5/8 thickness?
The steel wall thickness is 5/8 inch.  Your full-penn weld can't get thicker than that.
You can use a fillet weld (all around) of 5/8 inch.   12x20 HSS = 64 linear inches of weld.
This is a pipe support:  What are your loads?
I actually dont know the loads. This is coming from the design engineer who is presumably running them through some type of design program.
I had not considered the fillet weld. The weld we did has a cap of approximately 5/16" on top of it. So lets say I have a 5/8" thick member, I loose 1/8" from my land, then I loose lets say another 1/8" on top of that for joint inefficiency. If I had a 1/4" weld cap, would that add back to the strength of the joint?
If it were me, you need to disposition this weld by the design engineer, period. State your case like you did here and see what happens, By the way, I fully understand your argument but ultimately it comes down to design calculations and responsibility.
