International Work
International Work
Who has done international work?
Specifically done the design work in the U.S. for construction in a foreign country.
I have some general questions and maybe specific ones later on.
This would be for engineering work (structural, mechanical, electrical) pertaining to buildings.
Or if you have any links to helpful sources.
RE: International Work
What's your question?
What kind of code information is available?
Where do you go to get material availability information?
I guess I have big picture questions like the above for right now. Any information would be helpful. If you would prefer to discuss off site let me know.
Code information is normally easy to buy from the local standard shop, but local conditions is harder to find information on. I generally design it in my local code than try to convert it across to the other code. Sometimes the regions will accept any of the major codes as the basis for design.
Don't understand your last question.
How could you do anything so vicious? It was easy my dear, don't forget I spent two years as a building contractor. - Priscilla Presley & Ricardo Montalban
As for material availability, local contractors usually know these things.
Our clients were happy to engage us with knowledge of this agreement where we would complete concept and developed design (generally to US standards and at a slightly higher level of finishing that might normally be done) and oversee/review the detail phase - allowing that there might be a few amendments by the local consultant.
We did major equipment specifications, sequences and they would produce general specifications in the local language and translate drawing notes etc.
To minimize rework, we held a few early conference calls and discussed local code differences, brands/equipment availability or other peculiarities in the local market.
Note that we have only got this work for specialist services in an extended client relationship. eg. Data center work with a major US based client in an overseas office.
There is a professional engineer's commission and archtiect's commission.
If we were to go with a local entity to carry through on the design, where would we start looking?
Hard to say how to look without knowing which country, we usually use industry contacts - people we know from there who might know a few names.
http://www.nceng.com.au/
"A safe structure will be the one whose weakest link is never overloaded by the greatest force to which the structure is subjected" Petroski 1992
Our first potential international project is going to be done with someone with experience.
Thanks for all the information
