NX6 for the downloaded fasteners can you show detailed threads
I downloaded the components from cast. When I use a reusable component I don't see how to show the detailed threads. I see in the part file that it is controlled by a variable in an expression, but do not see that in the design table. If you use a reusable component how would you access these detailed threads?
RE: NX6 for the downloaded fasteners can you show detailed threads
To temporarily enable the display of detailed threads, set the fastener to be the work part, open the Expression dialog, find an expression named 'SYMBOL_SUP_STATUS', edit the value of this expression from '1' to '0' and hit OK.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
view style -> Threads (tab) -> use one of the threads standards that have "detailed" in the description
This works on standard mm and inch threads.
