Reinforcement of existing steel joist.
My issue is that I have an open web joist (LH series) that is over stressed about 10%. I believe I have two options at this point.
A. I can "cover plate" the existing joist.
B. try to spread the RTU weight over additional joists by "x-bridging" between additional joist. I think this would be the preferred option but I'm a little unsure how much "help" I can get from the additional joists.
If anyone has any insight to this issue I would greatly appreciated it.
RE: Reinforcement of existing steel joist.
SJI Technical Digest No. 12
Get creative with your new support beams - you might be able to tie back to existing I-beam or girder joist to pick up to as much as 50% of the load?? Spreading out the load over 4 joists will cut down your overload to like 2.5%!!! - IF done right.
Think outside the box a bit - you might be surprised.
We had to either relocate the equipment if acceptable to other parties, spread out the load, or come up with a dunnage to support the new equipment. Budget was never an issue.
While designing we always kept a provision of additional point load of 2 kips anywhere along the span of the joists, but accessibility for strengthening purposes was always an issue.
Designing with Vulcraft Steel Joists, Joist Girders and Steel Deck
For instance if you were to hang a load from below the joist, using a beam between two joists, the load would normally be distributed to each joist (based on distance from the load). If you were to use a larger spreader beam you could spread the load out to additional joists. It has to do with relative stiffness of the joists vs. the spreader beam.
They reviewed this at a seminar. I would assume this is in the SJI technical digest that JAE identified.
www.idecharlotte.com
