DI water corrosion of electronic components?
We use ultrasonic humidifiers with DI water to maintain proper humidity to suppress ESD in an electronic assembly area.
We have fried 4 power supplies in 5 months on our SMT assembly machines. We have a very troublesome buildup of contamination in all pick&place machines that we think is causing the failures.
This contamination is isolated to electrical systems and looks like hoarfrost, for lack of a better name. In particular, it shows up on some wires, fuses and circuit boards but not at all on others. The contamination build-up is on a supply in use for less than 6 months. Please me if you have any ideas what could be causing it. FYI we do not see this contamination on any other equipment in the facility and the area is climate controlled and ESD safe.
I have read that DI can attack copper; we have copper-leaded components on assemblies, but also solder (lead) coated components.
The most puzzling part of this is that we see a thin white powder coating on the insulation of power supply wires.
Can any of this be explained by humidified DI water?
Thanks-
john
Thanks-
john
twodogs
SUNSPOT Svcs.
RE: DI water corrosion of electronic components?
Mike Halloran
Pembroke Pines, FL, USA
There is all of the particulate that you are putting into the air.
DI is water is not high purity, just ion neutral. the stuff that is left is all put into the air by your humidifiers. Try using distilled water. I bet that you are finding this residue on other surfaces also it is just not causing problems, yet.
Plymouth Tube
When water evaporates, the salts in the water do not evaporate, the salts stay in the humidifier.
It doesn't matter what water you are using. If you use water with salts in it, the water is just going to crud up your humidifier, not crud up your building or products. The salts are not going to leave the humidifier.
DI water is also more or less the same as distilled water.
Distilled water (or DI water) is used in humidifiers so that the humidifiers don't crup up (scale up) and require periodic cleaning.
No, the DI water has nothing to do with your problem.
I would suspect that you have too much humidity in the conditioned air. If you keep the humidity below 40%, then you will not have corrosion.
Some users actually install dehumidifiers in facilities to lower the humidity and prevent corrosion.
http://ww
I would suspect that the white material is probably dust that settles out on damp surfaces.
You will have to balance out the humidity between preventing corrosion and preventing static.
You probably should contact a HVAC engineer that is familiar with the construction of electronic manufacturing buildings.
htt
DI water and white dust deposited ONLY on high current areas, not uniformly sprayed around chassis areas...
Correlations?
thanks-
twodogs
SUNSPOT Svcs.
The reason that people use pure water (DI, RO, Distilled, etc.) in a dehumidifier is that the salts that remain in the dehumidifier will be less volume than if you use a water with a high salt content.
It does not matter how the water vapor gets into the air because the salts do not travel with it. It is pure water in the air.
That is why, when it rains, you get pure water. Have you ever heard of it raining seawater? Of course not.
You just mentioned that you recently "fixed" the dehumidifier. That should ring a bell for you. You are now putting too much moisture into the air, which is causing your problems.
Suggest you try turning off the dehumidifiers and see if the problem goes away.
You really should consult with a HVAC engineer. Have him measure the humidity and give you a recommendation as to what the humidity should be.
High current = high local field strength. Anything in the air with a charge will be attracted.
That said, BIMR is right, the problem is probably too much humidity. The water itself isn't corrosive, but it is keeping surface deposits damp and that is leading to corrosion.
Either lower the humidity, or reduce the airflow through these cabinets so that they run hotter and have less risk for absorbing moisture.
Plymouth Tube
Does humidifier water eject anything else besides pure water into the air (it's ultrasonic)? I understand about the residual crust (we have none in the humidifiers).
How different would things be if we used 'softened' water?
We need to keep above 30%RH for ESD purposes and an infrequent oops is to leave heat off during a dark week-end, come in Monday AM, turn on the heat, and find HIGH (>70%RH) humidity. We are in Montana, humidity is low here and we need humidifiers to even reach 30%. Usually it is closer to 20%.
I'm thinking that high current as a static attractor si true here.
Thanks again.
john
twodogs
SUNSPOT Svcs.
If your humidifier were purely evaporative, only water vapour would be entering the air. But if it is ultrasonic, it actually throws tiny droplets of water into the air where they evaporate, leaving any TDS as dust. The lower the TDS of the water, the less dust you'll have to worry about.
The high relative humidity is likely the problem. You need a better humidistat.
"Ultrasonic humidifiers have a submerged vibrating disk that creates a high-frequency oscillation, expelling small water droplets into air. Many of these systems use DI or RO water and are used in applications where particulate-free humidity is essential but where a large capacity is not required. The disks require replacement after approximately 10,000 operating hours, which can be a concern for applications that cannot tolerate off-line time or the expense of disk replacement. Water droplets are generally small and maximum capacity is approximately 80 lbs/hr per unit."
If you have a good quality dehumifier, it should not be putting dust into the air.
http:/
And yes, we need a better humidistat to control both high & low RH.
thanks-
twodogs
SUNSPOT Svcs.
If you use distilled water, the only thing that'll be in there is what gets in there afterward, i.e. CO2 absorbed from the atmosphere etc.
If you use softened water instead of RO+DI water, the water will have sodium replacing the calcium/magnesium/iron that was in there to begin with. I don't know if this equates to "worse for electronics", but sodium carbonate is more soluble than calcium carbonate and hence more conductive in conditions which are not bone dry.
It sounds like you fixed a broken humidifier and now you're throwing more water into the air. The humidity is going up, but so is the dust load as a result. Best to control the humidity so you dump as little dust as possible into the air- or switch to an evaporative humidifier.
The reason you normally don't see severe corrosion from water is that it leaves minerals behind. In any house over a couple of years old, the is a layer of "lime" inside the copper or galvanized steel pipes. [limi is in parentheses because the deposit is semi-soluable and insoluable minerals leached from the ground. Some is lime, bou there are a LOT of other minerals in pipe scale] The water will never touch the metal inside the pipes. And the "lime" is a self-healing coating. When it gets scraped off, it replates onto the ID of the pipe.
DI/RO water has no minerals. It is typically tested for conductivity, to insure that there are no free ions of any kind. Without an added Inhibiter added to boiler feed water, the steel pipes would rust out in about 5 years. And that is inside a system with very, very little oxygen. Out in the open, you can get years of 'normal' corrosion in days by applying a light mist of DI/RO water. Fact of life.
Suggest that you go with either sealed, watertight cabinets, or use motor-winding varnish to 'paint' all the bare portions of your terminals and terminations. Varnish the relay enclosure boxes shut.
Unless the OP's room's HVAC is totally out of control, I doubt they're seeing condensation of liquid water on the surfaces where the OP is seeing the "hoar frost". If there is any corrosion happening, it is happening as a result of exposure to excessively humidified air, not exposure to a film of (deionized) condensate. I seriously doubt that the "hoar frost" that the OP is seeing is a corrosion product.
Your notion that deionized water is "extremely corrosive and hungry for ions" which you have repeated here is based on a misunderstanding of the underlying chemistry in my opinion.
It is true that deionized water will rapidly become contaminated with ions when passed through metallic piping systems, rendering it unfit for some uses- hence people use PFA or PVDF piping to keep the water pure in those applications. It is also true that a continuous supply of deionized water will, to the extent that it contains oxygen, cause corrosion of some metals, particularly iron and copper. It is also true that the addition of certain minerals and other additives can reduce the corrosivity of the water or aid in passivating the surface, rendering iron and copper adequately resistant despite the presence of oxygen.
It is quite another thing to conclude that there is a mechanism to support ongoing corrosion in a system merely because the first charge of water was deionized and hence (initially) "hungry for ions".
In a sealed system without oxygen, deionized water is not corrosive. In a system charged with oxygenated deionized water and then sealed, the oxygen will be rapidly depleted by corrosion, which will then STOP. In systems which are open, having a continuous feed such as your boiler feedwater example, the corrosion rate is related to the rate at which oxygen (or another electron acceptor in the case that the corrosion is occurring as a result of microorganisms) is fed and the rate at which the corrosion products are removed.
Take a sample of water from your humidifier, let it evaporate to dryness in a clear glass, and look for any residue.
Also, what do you think my 'hoarfrost' is?
Is it corrosion of the solder on the pcbs (I don't know if they are RHOS)? Why would it preferrentially be on the low voltage DC side? The power supplies affected are from a few different mfgrs. so I doubt it is a design or mfgr. failure. I see nothing on the surfaces around the power supplies that looks like deposited solids, just on the pcb itself and -puzzle- the high current DC wires from these supplies up to the 'parts' they energize.
Thanks-
twodogs
SUNSPOT Svcs.
"Pure, particulate-free humidity. When using DI or RO water, adiabatic systems with high-grade stainless steel parts can produce humidification as pure as the supply water."
If you have a good quality humifier, it should not be putting dust into the air.
http://
The second point is that one would expect that the white deposits are probably corrosion products on the metal because of high humidity.
I believe that the poster is saying that the white deposits are on metal not plastic components. That would indicated that the white deposits are from corrosion.
Try a test. Bag one component with a dessicant and leave another identical component out in the building air. After a few weeks, compare the components to see if the building air is causing the problem.
If the white deposits were on everything, the white material could be dust from the humidifier. If the white material is not over everything, then the white material is not dust.
A third point. If you are in fact making electronic components in a somewhat clean environment, why would you shut off the HVAC system that is conditioning the air on the weekends? If the building temperature drops over the weekend, it will cause the humidity to increase, resulting in condensation.
Consult with a HVAC engineering specialist. Have him measure the humidity and give you a recommendation as to how to operate your HVAC system for best results.
HVAC is 24/7. I checked and humidifier water is R.O. not D.I.
White dust is NOT on everything, just the DC side BUT this includes the insulation on the DC wires. Areas inside/around the pick&place machines have grey linty dust but none of this white crusty powder.
I'm working on a time-line, maybe that will give a clue.
john
twodogs
SUNSPOT Svcs.
Look-up how an electrostatic precipitator works. Installing one in your room would probably solve your problem. Changing to a steam humidifier would also probably solve your problem.
I don't believe there should be a significant difference between RO and DI water. RO units generally remove 95% of the salts where as DI units remove 100%.
You may condsider having the "crust" analyzed. The major dissolved salt component in RO/DI water is sodium hydroxide.
Do you have a picture of the dust?
I see that the fellows over in the HVAC forum are stating that the ultrasonic units are a maintenance nightmare:
http://www.eng-tips.com/viewthread.cfm?qid=309634
We are going to:
1.switch all humidifiers over to D.I.
2.seal all power supplies with conformal coating or Cortec anti-corrosive spray (some pcbs inaccessible).
3.Add ESD air spray of power supplies to monthly prevent.maint. schedule.
Thanks to all who noodled along with us thru this problem; I'm impressed with all the knowledge out there.
Regards-
john
twodogs
SUNSPOT Svcs.
twodogs
SUNSPOT Svcs.
