Dimensioning drawing|Break lines
When dimensioning a drawing, you can set the default gap between dimensions. Is there a way to create a gap between 'note' callout arrows, and dimensions?
SW Premium 2011
64 bit SP4.0
Intel Xenon X5650 @2.67GHz
2.66 GHz 11.9 GB of RAM
RE: Dimensioning drawing|Break lines
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
SW Premium 2011
64 bit SP4.0
TOP
CSWP, BSSE
Submit an ER if this is important to you or your company.
If the option is available for dimensions, it does make sense to have the same/similar option for notes.
